Adding key switch to original Comfort panel - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: FAQs - Technical (https://www.comfortforums.com/forum-16.html) +--- Thread: Adding key switch to original Comfort panel (/thread-5188.html) |
- mccltd - 06-20-2020 Hi, I have a comofort panel which must be about 18 years old now and still going strong. I presume its a comfort 1, not sure. Any how\'s I wish to add a remote to arm / disarm the unit and if I recall correctly when I installed it there was an option to add a key switch arm/disarm. I\'m presuming I could link it this but is there any info anywhere about adding the key switch and do I need to go into the programming of he unit? Thanks for your help - slychiu - 06-21-2020 Connect the key switch to any zone and program it as Switch Nornally Open Zone Type Assign one of the default responses Momentary switch Keyarm/Disarm to Away mode If SecurityMode = SecurityOff Then If AlarmState < Alert Then KeyswitchArm NightMode End If Else KeyswitchArm SecurityOff End If Momentary switch Keyarm/Disarm to Away mode If SecurityMode = SecurityOff And AlarmState < Alert Then KeyswitchArm AwayMode Else KeyswitchArm SecurityOff End If - mccltd - 06-21-2020 Thats great, thank you. I thought it could be done but couldn\'t remember how. - mccltd - 06-27-2020 Hi SlyChiu, I have just programmed the comfort with this and when I try shorting the zone 11 and common I get the Please exit and countdown but if I don\'t exit it goes back into security off. How could I have it so that when using the keypad I need to exit but if using the key switch I don\'t need to exit and it still arms? Regards Dave - slychiu - 06-28-2020 See the different ways of arming to Away Mode here http://www.comfortforums.com/forum125/2367.html If you want to arm to away mode without having to exit, use the action \"Auto arm Away\" instead of \"Key switch arm away mode\" |
