Comfort 1 version history - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Comfort I Issues (https://www.comfortforums.com/forum-101.html) +---- Thread: Comfort 1 version history (/thread-5115.html) |
- Home - 10-03-2019 Is there a simple version history for Comfort 1 available? We have a number of ICs for \'Outside\' and one labelled \'M4.83\' but we\'re not sure how the Comfort1 versions relate to each other. Also, what U4 ICs are compatible with each version if we ever have to change them. I know, I know.....You will say \'upgrade these systems to Comfort2\' (or is it Comfort3 now?) but sometimes the most cost effective method is to keep the original system running. - slychiu - 10-03-2019 The Comfort 1 Firmware History is attached. The last firmware 4.234 was in 2006 - Home - 10-04-2019 Thank you. But I\'m still not clear on the relationship between systems designated as Action, Entry, Master, Outside, Pagewatch, Pro, Rain, Ultra, etc. (Although I\'ve never seen a system designated as \'etc.\' )
- slychiu - 10-05-2019 Action, Entry, Master, Outside, Pagewatch, Pro, Rain, Ultra, etc. Entry - Comfort 1 with limited automationPro/Master - Comfort 1 with more automation, Ultra - Comfort 1 with even more automation! Pagewatch was for industrial monitoring Appications and Industrial wordlist Rain was a special version for some large projects for a specific customer Comfort 1 Pro should be the main version in the UK |
