NEW Comfort CPU pcb - Printable Version
+--- Thread: NEW Comfort CPU pcb (/thread-5003.html)
- Home - 01-13-2019
We have a new Comfort CPU 9000 - I note the following updates:
- The 8 outputs are removed from the main pcb and are on a daughter board. Would it not have made more sense to utilise an \'output\' UCM in this way it may have been possible to remotely connect or mount the utput board !
- EOL jumpers are now revoved and appear to work well in software. YES WORKS WELL.
- Tamper is now a three pin fixed to pcb - this is helpful for joining commons BUT its a different type of connector that sticks out of the side of the pcb - will this not cause problems in packaging !
- X10 removed - yep about time its totally redundent you cannot buy the X10 DIN modules now even Insteon replacements are not available.
Is there anything else we should know about!
- Home - 01-16-2019
I note that there is a new power supply
It appears to be a 15V DC (as opposed to the old 15V AC).
Presumably this is all ok with Comfort and has been soak tested etc.
- slychiu - 01-17-2019
Can you send a photo of the new board and power supply, to make sure that you have the correct set?
