AirCon Control - Printable Version
+--- Thread: AirCon Control (/thread-488.html)
- Patrick - 02-27-2007
Is there any limitation on which brand of aircon can turn on itself once you trigger it from panel using IR Code?
- nhard - 02-27-2007
Any IR code sent will apply the function of that code (e.g. ON) to any device that understands it.
You get IR code sets from .ifr files (see Comfigurator - Tools) or learn the code using a UCM/IR. See UCM manual for more detail on learning.
Hope that helps, but do post further as required.
Nigel
