UCM Firmware Update - Printable Version
+---- Thread: UCM Firmware Update (/thread-4560.html)
- davidsilva - 11-21-2016
Hello,
I have a CM9000-ULT. In software Configurator, the Confort Version is 7.116 and UCM01 is 5.192. When I try update UCM01 firmware to 7.026 I have the next error attached.
How I can update my UCM01?
Thanks.
- slychiu - 11-21-2016
You have UCM firmware 5. This cannot be used to upgrade the UCM itself or Comfort firmware using Comfigurator alone
You need UCM firmware t to do this
See \"different methods of upgrading Firmware\" in http://www.comfortforums.com/forum4/1783.html
You can only upgrade the UCM with firmware version 5 using another UCM and the programming cable
See \"Upgrading UCM, Slave or KT03 firmware using UCM Programming Cable\"
http://www.comfortforums.com/view_topic.php?id=1782&forum_id=4&jump_to=7048#p7048
Perhaps you can ask your distributor to upgrade the UCM for you, as he will have another UCM, or ask a friend who has a UCM for help or a loan
