Temperature from KNX - Printable Version
+--- Forum: KNX (EIB) (https://www.comfortforums.com/forum-12.html)
+--- Thread: Temperature from KNX (/thread-4542.html)
- marcobeleza - 10-20-2016
I am a user from Portugal and I have a problem in the KNX module when receiving temperatures from knx in celciuos. I assign a 2 byte object in knx and put it in a sensor, but the temperature values lost the decimal values in cytech. For example, 21.60ºC appears as 22 in cytech. Is there any way to keep the values with the decimal part?
Thanks,
- slychiu - 10-20-2016
UCM/KNX does not keep the fractional part of the temperature as there is no format to save it in Comfort sensors
We have not found any good application for fractions of a degree because most people  could not feel  the diference  Why is it important to you? How would you use it in Comfort?
- marcobeleza - 10-24-2016
Thanks for the quick reply. I was trying to use cytech to fully control my underfloor heating and my heatpump . The fractions of degree was important to show the exact temperature in each room and then control the target temperature of the heating.
Thanks,
