KP04 Screen problem - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: KP06/KP06A/KP04A Keypads (https://www.comfortforums.com/forum-105.html) +--- Thread: KP04 Screen problem (/thread-4424.html) |
- DavidJ - 03-31-2016 I have a KP04, quite old. About a year ago the screen turned very dark its like the contrast is turned to maximum, you cannot read or make anything out. I suspect the LCD has gone faulty, Is the LCD replaceable? - slychiu - 03-31-2016 The LCD is soldered in to the PCB with 19 pins so it is not easily replaceable unless you are a skilled solderer |
