Motorized Gate Status - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Motorized Gate Status (/thread-442.html) |
- Howser - 01-23-2007 [font=\"Times New Roman\"]I am installing a sliding gate that uses a standard controller which can drive a remote led (wired) to indicate status.[/font] [font=\"Times New Roman\"] [/font] [font=\"Times New Roman\"]It is documented on the product that led will indicate the following conditions;[/font] [font=\"Times New Roman\"]Slow regular flash----------------Gate is opening[/font] [font=\"Times New Roman\"]Quick regular flash---------------Gate is closing[/font] [font=\"Times New Roman\"]Off-------------------------------Gate closed[/font] [font=\"Times New Roman\"]On-------------------------------Gate open[/font] [font=\"Times New Roman\"]1 Flash/2 seconds----------------Courtesy Light switched on[/font] [font=\"Times New Roman\"]2 Flashes/2 seconds--------------Mains/power Failure[/font] [font=\"Times New Roman\"]3 Flashes/2 seconds--------------Backup battery Low[/font] [font=\"Times New Roman\"]4 Flashes/2 seconds--------------Gate collision detected.[/font] [font=\"Times New Roman\"]Is there a way that I can get my Comfort panel to announce the above conditions?[/font] - slychiu - 01-23-2007 You may be able to just indicate open or closed based on the status of the LED, but not all the quick./slow flashes However you cannot connect the LED points directly to Comfort inputs. You wil have to study the driving circuit and to design an interfacing circuit to provide an open/close contact to Comforts inputs. It is not a task I would really recommend |
