Unable to see Zone Names and Control Menu - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort Android App (https://www.comfortforums.com/forum-110.html) +--- Thread: Unable to see Zone Names and Control Menu (/thread-4248.html) |
- slychiu - 07-12-2015 If you have followed the instructions in sending the email to your phone, and tapping the attachment in the email to \"Open In Comfort\" but cannot see the zone names in the Zones Page or the Control Menu in the Control Page, there may be several reasons for this
- slychiu - 07-30-2015 When you make changes to the cclx file with the same name which has been already sent to the app, please delete the earlier email with attachment. see http://www.comfortforums.com/view_topic.php?id=4289&forum_id=122 - slychiu - 08-27-2015 Zone Name or Control Menu or Control Group names are blank This may happen if you have entered text in \"Alternative Phrase\" but later deleted the text. If Alternative Phrase is empty, the Zone words or Control words are used in the Zone or Control menu words. If there is text in Alternative Phrase, then that text is used instead. But if you entered text in Alternative phrase and later deleted it, the empty phrase is still used as text in the zone or Control menu The work-around is to enter text again in the Alternative Phrase so it is not empty Hence the rule is ; if you enter text in alternative phrase, you should not delete the text - you can change the text to what you want. |
