Can the Door Station Button execute a response? - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html) +--- Thread: Can the Door Station Button execute a response? (/thread-4056.html) |
- hasan hadi - 11-22-2014 Hi, how can using door station for execution any response for example i need when press button in door station the output1 is on how can doing it note the type for door station is DP03 Regards - slychiu - 11-22-2014 Events > Misc Events > Doorbell Response The doorbell Response is activated by a doorbell press at any time The Doorbell Alarm Type can also activate a Response in Alarm Types > Doorbell The difference is that the Doorbell Alarm Type happens only when the doorbell is presed in Away or Vacation Mode, while the Doorbell Response is anytime the doorbel is pressed - hasan hadi - 11-22-2014 [user=1]slychiu[/user] wrote: Quote:Events > Misc Events > Doorbell ResponseThanks , the work is done please what means \" open door \" or \" open Gate\" - CytechMartin - 11-22-2014 Open Door Response This specifies a Response to be activated when \"7 to Open Door\" in the Door Station Menu is pressed. This happens after the doorbell is pressed. Open Gate Response This specifies a Response to be activated when \"4 to Open Gate\" in the Door Station Menu is pressed. This happens after the doorbell is pressed. For more information, you may download the programming manual here https://www.cytech.biz/programming_with_comfigurator.html?category_id=106 |
