programmed camera - Printable Version
+--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html)
+--- Thread: programmed camera (/thread-3947.html)
- hasan hadi - 08-29-2014
Hi, how can programmed camera i now using ip but how programmedalso i need wring
regards
- ident - 08-29-2014
There is no programming of IP cameras
IP cameras are independent of Comfort and do not need to be programmed by it
You may be able to view IP cameras via the Comfort iOS or android apps if the models  are supported
Otherwise there is no interface or control of cameras
Hi,thank youthis mean input ip in application ((apple or android))  and can be after that arrive to camera
also must be connect camera to internet  Regards
- ident - 08-30-2014
You need IP cameras in order that you can view them from the Comfort iOS or android app.
