I need help for DM02 Door - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html) +--- Thread: I need help for DM02 Door (/thread-3946.html) |
- hasan hadi - 08-28-2014 HI please can be any one explain about DM02 Door 1- i need wiring 2- how can programmed by using Comfigurator Regards Hasan - ident - 08-29-2014 Please download the DM02 manual from the website, see https://www.cytech.biz/dm02_manual.html Each one of our products has a manual, which you can find from https://www.cytech.biz/manuals.html If you have any questions on wiring or installation, please go to that site to llook for the relevant manual which will provide all the information If there is anything you do not understand or require additional information then this forum is the correct place to ask - hasan hadi - 08-29-2014 [user=86]ident[/user] wrote: Quote:Please download the DM02 manual from the website, see https://www.cytech.biz/dm02_manual.htmlthank you siryes I reading maunal and have some eq.1- the DM02 using only one door or more 2-can be connected door station directly to comfort without using DM02 if yes how connect it?3-if have more from 3 door station what doing because i know max door station connected to comfort is 3 4- this standard or notthis from manual \"\" the ID for thedoor station (49 for ID 1, 50 for ID 2, and 51 for ID 3). \"\" i mean number 49,50 ,51 5- please can give me example how programmed door station one and more from one Regards - ident - 08-30-2014 Quote:1- the DM02 using only one door or moreyou need 1 DM02 for each DS01 or DS02 door station. when you buy DS01 or DS02 bundle the DM02 is included Quote:2-can be connected door station directly to comfort without using DM02 if yes how connect it?Only DP03 plastic door station can be cnnected to Comfort without DM02 But this can discolour when installed in the hot sun and rain so DS01 or DS02 is preferred Quote:3-if have more from 3 door station what doing because i know max door station connected to comfort is 3Max door station is 3 Quote:4- this standard or not this from manual \"\" the ID for the door station (49 for ID 1, 50 for ID 2, and 51 for ID 3). \"\" i mean number 49,50 ,51ID is 1, 2,3 49, 50, 51 are the numbers when the door station is reported in the evvent log Ignore this for now Quote:5- please can give me example how programmed door station one and more from one You do not have to program the door station You need to set the IDs to 1,2,3 if you have 3 door stations Then use Comfigurator and Scan for modules so it can find the 3 door stations, then write to Comfort. The 3 door stations will then work |
