KNX and AV control - Printable Version
+--- Thread: KNX and AV control (/thread-3918.html)
- Bitscraft - 08-09-2014
Is Anyone has an easy approach to control domestic AV system which has IR remotes. Is there any app available to control KNX installation of home and choose the AV devices without depending on two app.
send me info to my email
info@bitscraftintegration.com
- ident - 08-10-2014
You can learn IR codes into Comfort using a UCM/USB or UCM/Eth03
The IR codes can be sent to any Comfort output to control your AV
The comfort iOS and Android apps can be used to control the AV devices by IR
The same app can also control KNX and other devices
It does not look as nice as a Crestron or Control4, but it can do the job
