Control Menu guide - Printable Version
+--- Thread: Control Menu guide (/thread-3765.html)
- cc_uk - 04-13-2014
I am finding my way around the Comfort system, and find the way it\'s been designed excellent.  In addition support from Cytech is superb.
Can someone direct me to a guide on how to use the Control Menu options?    I can\'t quite get around how this is supposed to work.
The other area that would be good if there is a guide is under the Functions menu -> Thermostats
- ident - 04-13-2014
There should be instructions for the control menu in Programming with Comfigurator which you can download from https://www.cytech.biz/programming_with_comfigurator.html which has been updated for Comfigurator 3.8
It is not complete so the thermostat and blinds functions may not be included yet
Blinds are described in http://www.comfortforums.com/forum20/3549.html and Thermostat function in http://www.comfortforums.com/forum42/3547.html
