Thermo Sensor for aquarium - Printable Version
+--- Thread: Thermo Sensor for aquarium (/thread-3760.html)
- nbexiga - 04-09-2014
I have an aquarium, and i want to know if it\'s possible to connect to my central (SPC - Portugal) a thermo sensor that when the aquarium water goes up to 26.5º it turn on the air condicioner until it reaches again the 26.5 maximum , and when goes under 24º it turn on the air conditioner again until it reaches the 24 minimum again.
Is is possible to get a sensor and connect to the central? It would have to be a sensor that goes to the water.
I really need this ASAP because the summer it\'s coming and i want to avoid to buy a chiller.
- ident - 04-11-2014
I do not know of any temperature sensors that can go into teh water and are compatible with Comfort. KNX perhaps?
- nbexiga - 04-11-2014
hi
i don\'t know , that why i ask if comfort have.. but seems don.t SadSad i would be really appreciated if someone can help me. because if i can use confort i would avoid to buy a separate sensor....
i am talking about this one...
for ex
ATC 800+
- juwi_uk - 04-12-2014
If you had a Zwave ucm you probably could put something together using the 2 bits below and mounting in a small plastic box.
http://www.zwave-store.co.uk/fibaro-temperature-sensor-waterproof
http://www.zwave-store.co.uk/fibaro-universal-binary-sensor
I guess it boils down to cost etc.
