ETH03 module - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Thread: ETH03 module (/thread-3745.html) |
- cc_uk - 03-28-2014 Is there a minimum UCM hardware revision required to support the ETH03 module? Will it work on an older series UCM card that has an ETH01? - juwi_uk - 03-28-2014 Firstly the UCM has to be one that is flash upgradeable. Then IMHO it just boils down to whether it fits. I have on my test kit one of the first GEN flash UCM\'s that also had a 9-pin serial port on the baseboard. Whilst Eth1 & 2 fitted quite nicely because they had a cut-out in the PCB, eth3 doesn\'t so I cant use. I\'m quite sure if it\'s \"flash-and-fits it\'ll work\"! I\'m sure Cytech will confirm or shoot me down in flames thought! Julian - ident - 03-29-2014 Correct You need a UCM that has flash ie min firmware 5.100 The ETH submodule can be plugged on top |
