Doorphone Doorentry - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Doorphone Doorentry (/thread-372.html) |
- rodime - 12-09-2006 Hello, I have enabled door entry on the doorphone so that I can let someone into the house remotely. I have associated a response to the Open Door misc event which disarms the security for 30 seconds before rearming. The idea is to let a delivery or postman into the hall who has 30 seconds to leave before security is automatically rearmed. This is activated using key 7 on the phone. Is it possible to add a second key (8 perhaps) as an open door response that I can associate to a different response. The idea being to open the door and disable the security entirely, if it is someone I want to let in and stay in. I am guessing I could use open gate as it is currently free, but if it was not is there another way? - slychiu - 12-10-2006 You could press # to exit from the Door station Menu, system will say \"thank you goodbye\", Before the sentence ends, Press *, enter your code and # key and sign in again This allows you to do anything on the user menu like disarm system or go to Home control Menu. You cannot access these in the Door Station Menu as you have not signed in - rodime - 12-10-2006 thanks |
