Action 102 - Alarm Zone - Printable Version
+--- Thread: Action 102 - Alarm Zone (/thread-3652.html)
- HenleyBranch - 12-23-2013
Hi there,
I have two rooms I want to have a monitoring alarm call on when the system is disarmed - i.e. receive a call if someone unlocks and goes into the rooms when the system is in Security Off - I have therefore set a conditional action \'on response\' using Action 102 (as in Away mode I want the sensors to function as normal security sensors).
I am using a Familycare Alarm using Action 102, which works except the Zone doesn\'t announce in the alarm call, which means I don\'t know which of the two spaces have been entered.
Anyone know what am I doing wrong?
Henley
- ident - 12-23-2013
Action 102 reports the last zone in alarm so it may not give the zone you need
I suggest to use another unused alarm type for the other znes ie 2 alarm types for 2 zones you want to report so that each alarm type is for one zone report only
Thanks ident, I\'ll try that.
Neither zone is in \'alarm\', as such because the system is disarmed and the sensors remain part of the alarm system - i.e. zone alert type.
I am using action 102 in an On Response with a conditional if security mode = \'security off\'.
Henley
- Home - 12-23-2013
Bear in mind that you wont get this to work on a C1 board - your other post as well NEEDS a C2 board upgraded to the latest firmware.
