Using Sunrise and Sunset times - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Using Sunrise and Sunset times (/thread-3600.html) |
- Guest - 11-14-2013 I have and Ultra II and have calculated D&D times from Lat and Long. The problem is how to use the times. I wish to do this: If Time= Dawn and Time > 0700hrs Then Do something So far I have been unable to fgind anyway of programming in D&D from the responses wizard. Do I need to go to Action Codes for this? - ident - 11-15-2013 Use the Sunrise / Sunset times in Comfigurator, see http://www.comfortforums.com/forum92/1004.html The Night Flag is a dedicated flag that is set between sunset and sunrise that you can use in your logic |
