Spk at doorstation very soft. - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html) +--- Thread: Spk at doorstation very soft. (/thread-3599.html) |
- kodomo - 11-14-2013 In case communication form door to indoor Spk at doorstation very soft. but Sound to Keypad or Telphone ok very good. I adjust the speaker door-station to max, not work. I change new cable, not work. I change parameter at comfigurator, not work. How to fix it ? - ident - 11-14-2013 Which keypad and door station models are you using? The KP06 and KT03, and DS01 have better performance for eacho cancelllation that other door stations and keypads One mistake when having low volume to door station speaker is to adjust the door station volume louder. This will not work because the system does echo cancellation. If the total volume gain is high the system will reduce the gain of one side Instead reduce the volume from Door station to Keypad Load the default tuning parameters as a start The Tuning Parameters Guide can be downloaded from https://www.cytech.biz/tuning_parameters_guide.html?category_id=99 Figures 4 and 5 show the block diagram for KP to DP intercom Tuning Parameter 81 (AFE DP Mic Gain) default is 3. Reduce to 1 to reduce the gain of DP Mic to KP speaker. Reset the system Try the volume at both sides before anything else - kodomo - 11-14-2013 DM02+RGR05+KP03 - ident - 11-14-2013 For KP03 as well as the above steps, reduce the volume control so that the volume of the person talking at the Door station is not loud. This will allow the keypad to door station volume to be louder The more you make the door station to keypad louder, the softer will be keypad to door station Make sure the KP03 has the internal black accoustic filler. If that is removed then it will be difficult to get adequate volume - kodomo - 11-14-2013 Tomorrow I will go back to site again. and Follow your instructions. Thank u. |
