Comfigurator zone status - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Comfigurator zone status (/thread-3586.html) |
- gjb - 11-04-2013 In the zone properties, what do \'Show Status\' and \'Module Status\' do? I cannot find these settings in the documentation. Thanks. - Vangelis - 11-05-2013 Show Status, i think, show the status of a zone sensor eg Open / Closed in the Comfigurator Status panel and also on the Smart Phone App Not so sure on Module Status however... Vangelis - ident - 11-05-2013 If you check the \"Show status\" button, the zone status of all zones will be shown on Module Status and any change in zones will be updated In your screenshot you have Module Status as On, which means zone 6 (Back Door) is Open There are also \"Show Status\" buttons for Counters, Flags, Sensors, Outputs which show the status of these registers in Comfort This is used in Comfigurator only, it does not affect the iphone/ipad app which always shows status - gjb - 11-05-2013 I was confused because it appears that you can enable/disable \'Show Status\' for each zone, when in fact it is a global setting that applies to all zones. Thanks for explaining. This is a useful feature while I am building my system. |
