Arduino - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Arduino (/thread-3536.html) |
- bryanajones - 09-29-2013 Hi, I\'ve recently been looking into Arduino. My question is would it be possible to get an Arduino to trigger the inputs on Comfort? If so, how would I go about this? (is it as straight forward as a single wire from an Arduino output to a Comfort input?) Thanks Bryan. - slychiu - 09-30-2013 Yes you can trigger an input of Comfort from an Arduino ouput but take note that the Comfort input accepts 0 to 3 V Set zone type as Digital N/O or Digital N/C - Vangelis - 09-30-2013 From recollection, Arduino uses either 3.3v or 5v TTL, so dependant on which board you use, the OP may need some extra circuitry Vangelis |
