Temperature sensor - Printable Version
+--- Forum: Questions on Programming Comfort (https://www.comfortforums.com/forum-83.html)
+--- Thread: Temperature sensor (/thread-3416.html)
- moh20 - 06-13-2013
hello ..  i want to make temperature sensor .. that measure room temperature
( for example 25 centigrade ) and if this temperature raise over this limit turn on air condition .. and if it below this limit turn on electric heater .. what is the program ? & what is zone type ?
- ident - 06-14-2013
You can use SCS Scene control Switch
This include a temperature sensor which is mapped to Comfort sensors
Sensor Response can be programmed eg
If LastSensor Value > 25 then Do Response Turn on A/C
 Else If Last Sensor Value < 20 then Do Response Turn off A/C
Else If Last Sensor Vale > 19 then Do Response Turn off Heater
Else If Last Sensor Value < 16 then Do Response TurnonHeater
Please read the SCS Manual from https://www.cytech.biz/scs_manual.html?category_id=117
- moh20 - 06-14-2013
always cytech helping us >>>> thanks alot
