CLIPSAL MinderPro Premise - Printable Version
+--- Thread: CLIPSAL MinderPro Premise (/thread-3273.html)
- mrkenjiro - 01-30-2013
I am not sure if this is the right forum to post this but I understood that this model is also sold under COMFORT.
My double house is supplied with this security system and I need to know how to program the following:
1. Night Mode -
Current Setup - All PIR and Vibration Sensor are armed.
Desired Setup - Ground Floor\'s vibration sensor are armed. Only PIR at the attic are armed. The rest are off. It\'s very humid in Malaysia and I need to open my balcony door and window. How do I go about doing that? Can I do a programming on the LCD panel itself?
- ident - 01-30-2013
I suggest that We recommend an experienced Comfort/MinderPro installer to reprogram your system, as any wrong programming can render the system inoperative. There are many installers who know Comfort in Malaysia
- mrkenjiro - 02-05-2013
Could you recommend a installer that is based in KL along with his/her contact no?
- ident - 02-05-2013
I have sent a Private Message to your username
Please check your email
