activate output from keypad - Printable Version
+--- Thread: activate output from keypad (/thread-3219.html)
- boltz - 12-31-2012
I\'d like to be able to press, say F,4 and it activate an output when the keypad is not signed in i.e the system is in normal operation in day mode, is this possible without having to sign in...?
- ident - 12-31-2012
yes go to Control > Keypad
You can program any response for the keys 0 to 9 and *
eg program key 4 with a Response menas Press F4 will activate the Response
Uncheck need code so you do not need a code to use the function key
