New Project Requirement - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: New Project Requirement (/thread-3168.html) |
- joshua963 - 11-20-2012 I have a new project requirement as per below : 1). Zone 12 - Use as keyswitch to Arm to Nightmode and to Disarm System (First time contact closed and opened Arms to Nightmode, the second time contacts closed and opened to Standy Mode or Disarm) 2). Zone 13 - Trigger alarm delay only when in Away Mode, When in Night Mode would trigger alarm instantly 3). When alarm is triggered, output 6 should be activated and after sign in output 6 is off. 4). Output programming from output 1 to 5 to control lighting. Eg : Output 1 is for Living Light, 2 for Dining Light and etc.. Hopefully the support team could provide me a sample programming with the above requirements in cclx format Thank you. Regards, Joshua - hendy - 11-22-2012
