Comfort II panel resetting itself - Printable Version
+--- Thread: Comfort II panel resetting itself (/thread-3101.html)
Pages: 1 2
- Ingo - 01-07-2013
Try and remove items one at a time to see which one \'might\' be causing it.
- ident - 01-07-2013
Maybe you can even start with a default template and trigger an alarm, see if that causes the reset
- Home - 01-07-2013
OK
Tell me HOW ALL of the tampers are wired,,,,,,
Also are any of your zones wired EOL?
- Howser - 01-11-2013
After further investigations, it seems the Alarm Company\'s (Long Range Wireless) radio was interfering with the panel.
The antenna was moved away from the panel, and it looks like the problem is sorted.
- ident - 01-12-2013
Interesting, I did not expect wireless to affect Comfort. What is the long range wireless device? Normally these devices shhould be limited in power so they dont affect other electronic equipment
- Howser - 01-12-2013
[user=86]ident[/user] wrote:
Quote:Interesting, I did not expect wireless to affect Comfort. What is the long range wireless device? Normally these devices shhould be limited in power so they dont affect other electronic equipment
The device is similar to the one on the link - http://www.advancedalarm.com/LRRadioMntrng.html. It seems it was the transmitted signal that was interfering and not the drawn power.
