Alarm Log - Printable Version
+--- Thread: Alarm Log (/thread-3034.html)
- shah - 08-23-2012
Event 1
07/16 17:16 Alarm Type # Intruder (1)
07/16 17:16 Zone Activation # Shoerack (11)
07/16 17:16 Bypass Zone # Living (10)
07/16 17:16 Alarm Type # BypassZone (16)
Event 2
07/17 21:50 Mode Change # Night Mode
07/17 21:51 Bypass Zone # Living (10)
On event 1 , there is an event (07/16 17:16 Alarm Type # BypassZone (16)) , what does this mean? What is the different between (Bypass Zone # Living (10), and Alarm Type # BypassZone (16)). Is that because that particular zone triggered the alarm, the system bypass it automatically? This might be fundamental but thanks.
Rgds
Shah
- ident - 08-23-2012
The Bypass zone event shows the zone bypassed
The Bypass Alarm Type is the alarm triggered by the Bypass zone
A Bypass zone event triggers a Bypass Alarm Type because the alarm type can be programmed to dial out and trigger a Response
Hence any bypassed zone triggers the Bypass alarm type
However I do not know what caused the Living room zone to be bypassed. This is not automatic, it has to be programmed somewhere, which you should check
