Comfort and Velbus - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Velbus (https://www.comfortforums.com/forum-88.html) +--- Thread: Comfort and Velbus (/thread-2827.html) |
- wexfordman - 04-12-2012 Hi, Been doing a bit of a refurb at home, and as part of it have removed all my x10 hardware and replaced it with velbus, and installed the ucm/velbus so that it could be integrated with comfort. Thought my experience might be of use to others, so have put together a bit of an overview and attached it for anyone who would be interested. Regards, Eamon File was too large to upload, but you can find it here https://docs.google.com/open?id=0B1zlDoqP2HdxUGVJdnY3WGtYamM Regards, Eamon - ident - 04-13-2012 Thanks, that is fantastic But the last page 31 of the PDF seems to be cut off - wexfordman - 04-13-2012 Hi, Thanks! Yep, sorry about that, I will fix it , will also add a link to the combined template which was originally in one doc! Regards Eamon - wexfordman - 04-13-2012 Hi Ident, Fixed that and a few other typos etc. Regards, Eamon - dubourg - 04-17-2012 Eamon I\'d like to say thanks for the time and effort you put into your guide. As a fellow self installer it is very useful to gain insights into how others have done it! Unfortunately I\'m not able to install a centrally controlled bus lighting system as I would need to completely re-wire. So I\'m sitting on the fence until z-wave can prove it can provide a reliable and cost effective solution. Thanks again! - wexfordman - 04-17-2012 Hi Duborg, thanks for the feedback, glad you found it informative. Are you using x10 at the moment ? - slychiu - 02-17-2018 That link https://docs.google.com/open?id=0B1zlDoqP2HdxUGVJdnY3WGtYamM does not seem to be working now? It does not alllow sign in to google? - wexfordman - 02-17-2018 https://drive.google.com/a/glenegare.com/file/d/0B1zlDoqP2HdxUGVJdnY3WGtYamM/view?usp=drivesdk Just worked for me from my phone ? It\'s set to share eetc ? If you want I can email you to you ? |
