power failure proof - Printable Version
+--- Thread: power failure proof (/thread-2781.html)
- WMADKOUR - 03-18-2012
i need to make a response to be activated on a certain date, but i face the problem of power failure, when power failed as well as battery discarged the time reset,my Question is ?  is there is any way to make a response triggered on predefined date by something not effected by power failure or is there is any way to restore last date on power failure restore ?
and is there is any way that  power failure do not reset Timers or counters or flags?
- ident - 03-19-2012
Power failure wil battery discharged will reset all counters and other registers and date and time (but will not affect the program or configuration)
Perhaps you need a larger battery or more batteries to back up the system
