Siren reverse SEM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: FAQs - Technical (https://www.comfortforums.com/forum-16.html) +--- Thread: Siren reverse SEM (/thread-2517.html) |
- TheMax74 - 10-15-2011 How can i activate \"siren reverse\" on SEMS? Thanks - ident - 10-16-2011 Siren Revese is not applicable for Slaves In fact it is rarely used even on the Main Comfort controller Are you sure you need it? - TheMax74 - 10-16-2011 Yes, i\'ve got 3 sirens, one wired to the maìn panel, one to sem 1 and one to sem 2. For now i can use a relay to overcome the problem, but may be useful if the checkbox \"siren reverse\" will work even for SEM\'S Thanks. - ident - 10-16-2011 Can you use the connections shown in http://www.comfortforums.com/forum16/2288.html to connect to the siren on the slave? Most sirens will work like that, - TheMax74 - 10-16-2011 Thanks, already done this in main comfort panel. For SEMS, i use a relay to simulate \"siren reverse\" option. Don\'t worry. |
