Answer Machine - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Answer Machine (/thread-2498.html) |
- raygregg114 - 10-06-2011 Hi, does comfort come with an answer machine and if so can it be set up through comfigurator 3.3.3 as i don\'t seem to be able to do so. - slychiu - 10-07-2011 Comfort does come with an answering machine Be default Comfort answers the phone after the Number of Rings in Comfigurator Telecoms > Answering If no Greeting message is recorded, Comfort says \"Please Sign in\" You can enter * and user code and # key to access the user menu If you record a Greeting message, then the caller will hear this message and can record a message. This will cause the MSG led on the keypads to flash Enter your code on any keypad to hear the message The Greeting message must be recorded on the telephone or keypad, not by Comfigurator. Using the telephone or keypad, go to User Menu, press 9 for Program menu, 1 for answering, 3 to record Greeting message By the way these voice menus and how to use Comfort are documented in the Comfort User Manuals which come with the products and can be downloaded from https://www.cytech.biz/user_manual.html - Guest - 10-11-2012 Hi, I have recorded the greeting message and also set the \"rings before answer-security off\" to 5. however when i call my landline , comfort does not answer my call . What have i missed ? Thanks - ident - 10-12-2012 Please refer to topic at http://www.comfortforums.com/forum17/57.html |
