Response for Output signal 1 min on / 1 min off - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Response for Output signal 1 min on / 1 min off (/thread-245.html) |
- mindi65 - 10-21-2006 Hi [img]file:///C:/DOCUME%7E1/Marelis/LOCALS%7E1/Temp/moz-screenshot.jpg[/img]System information Ultra Action 4.206 UCM 5.43 16out/16 inp + 2*RIO (16+16) How to program response trigering an output for 60 sec ON and then 30 sec OFF and again 60/30/60/30 ... ? This shall load system as less as posible. This response (action) shall be stoped by some inputs Regards Mindaugas - slychiu - 10-22-2006 Response OPON: Do Output1ON [Output 1 ON] Do OPOFF [OP OFF 30 seconds] After 60 Seconds Using Timer01 Response OPOFF: Do Output1OFF [Output 1 OFF] Do OPON [O/P ON 60 sec] After 30 Seconds Using Timer01 Stop Timer Response: Stop Timer Timer01 The first response will turn on O/P 1 and start a timer for 60 seconds using Timer 1 At the end of the Timer, the second Response is activated which turns off O/P 1 and starts Timer 1 for 30 seconds then back to the first response, and so on in a continuous loop To stop this cycle call the 3rd response which stops the timer |
