CAT5e for PIR runs - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: CAT5e for PIR runs (/thread-2421.html) |
- stedaniels - 08-17-2011 Hi, I\'m rewiring a 1960\'s house at the moment (just bought last month, stripped and chasing out walls over the next week or so). I\'m putting a fair bit of CAT5e in for networking and some other low voltage stuff. Can I just do additional runs for the PIR\'s? All runs should be less than 10m, though they will have to run parallel for a couple of metres with a fair bit of mains wiring at a separation distance of 2\". Thanks, Steve - slychiu - 08-17-2011 I expect PIR wiring should not cause much problem, although a further disance from the mains would be more comfortable. You never know what effect itg may have over the long run I prefer alarm cable for PIRs and alarm sensors- more flexible and less likely to break but CAT should be OK |
