Outputs of Living room lights get stuck (PLEASE HELP) - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: Outputs of Living room lights get stuck (PLEASE HELP) (/thread-2378.html) |
- nbexiga - 08-01-2011 Good afternoon. I have a comfort system II SPC. 5206 File System Version 30. I have one Ethernet and UCM Board installed.I Ever had problems in the installation, Until the last technician was at my house that switched the entire installation (including cables and all the boards (UCM and mainsboard) and the situation persists.It\'s all working ok, until the lights in the living room block, when I click the push button and also when I toggle the button the light of the living room blocks, thus failing to turn on or off the room lights (all the rest of the system it works , even throught the Comfigurator). Everytime this happens i have to reset comfort for i can turn on and off the lights again. but another issue is that not in every reset... i can\'t get a line of when this happens... I can not figure out why it blocks only part of the room lights.Can someone please help? Many Thanks. Nuno - ident - 08-02-2011 Can you send the cclx file to support@cytech.biz and describe the exact sequence for how to duplicate the problem you mention - nbexiga - 08-02-2011 HI, I\'ve just sent the .cclx file. Waiting for reply. many thanks |
