DP02/MC camera to IP - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html) +--- Thread: DP02/MC camera to IP (/thread-2375.html) |
- kevinsales - 07-31-2011 Hi, So long as i have been living in this house the camera on my doorstation hasnt worked, iam not sure if it is even connected, however iam going to be checking all this in the coming weeks, i was wanting to know if anyone has had experiance of converting the coax cable and analog signal into an IP based system as iam looking to install other cameras on an IP system it makes sense to install my DP02/MC on the same sytsem. and hopefull use the webserver to view at a later date. Regards - bs85 - 07-31-2011 I use Axis video encoders they work well but are quite expensive. there are plenty of others out there. here is a single channel. http://www.henrys.co.uk/cctv/videowebserver.htm - ndh - 08-15-2011 Think you may need an Aviosys IP 9100A? (from Digidave). Thriving hacks for these out there. Think there is a yahoo group. Nigel - kevinsales - 08-15-2011 Thanks, i shall have a good look at both systems. |
