UCM/KNX 5.234 - Printable Version
+--- Forum: KNX (EIB) (https://www.comfortforums.com/forum-12.html)
+---- Forum: UCM/KNX Firmware (https://www.comfortforums.com/forum-89.html)
+---- Thread: UCM/KNX 5.234 (/thread-2294.html)
- ident - 06-10-2011
The new UCM/KNX Firmware 5.234 can  be downloaded from https://www.cytech.biz/ucmknx_firmware.html
A new UCM/KNX manual is also available from https://www.cytech.biz/ucmknx_manual.html
Known Issues
  1. KNX relative dim levels are wrong when SCALE switch is shunted
  2. KNX Floating point EIS5 calculation wrong
Bugs Fixed
  1. When zones are bypassed from Comfort, the mapped KNX group address is not updated with the bypass state
Note that Comfigurator 3.2.9 allows the UCM/KNX Physical address to specify Area 0 (previously areas 1 to 15 only), Line 0 (previously 1 to 15 only) and Address 1 to 255 (previously 1 to 200). This is not a firmware function
