Siren Connection - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Siren Connection (/thread-2263.html) |
- emabonacchi - 05-19-2011 Hello and first of all, scuse me for my bad english. I don\'t know if this is the right place in this forum, but i have a question about installing and configuring the external siren. Well, my external siren, has an internal backup battery, a 12v+ cable, a - cable, 2 tamper cables and a cable normally disconnected. When an alarm occours, this cable must be connected to a - and then, the siren play the sound. How can i connect it to comfort? If i connect it in \'reverse mode\', i suppose it works fine, but i think it always uses the backup internal battery to play the sound, so i think it is not a good idea. Do you have any suggestion? Thank you Emanuele from Italy - ident - 05-20-2011 Figure 2.5 in the Installation Manual shows the siren connections for a self actuated siren https://www.cytech.biz/installation_manual.html?category_id=106 The diagram is also shown below - emabonacchi - 05-20-2011 I know the diagram about siren connection, but i suppose my siren need a different way to connect. My siren has 3 cables: red and black cable, need to be continuosly connected to 12v + -. green cable, needs to be normally disconnected and when an alarm occours, it must be connected to the -. So, how can i connect these 3 cables? - ident - 05-20-2011 Your siren does not need a special way to connect at all. The diagram above applies to it In the diagram above, there is a 12V and Com on the siren which must be connected to Comfoort 12V and Com There is a Negative trigger on the siren which is connected to SRN-. When an alarm occurs the SRN- is pulled to 0V and triggers the siren - emabonacchi - 05-27-2011 Ok, thank you very much. |
