Comfort Firmware 5.207 - Printable Version
+--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html)
+---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html)
+---- Thread: Comfort Firmware 5.207 (/thread-2169.html)
- slychiu - 02-20-2011
Bugs Fixed
  1. Fix BUG F8 followed by 0 will turn off all KP spkr and mic
  2. Fixed BUG UCM01  cannot work with Comfigurator 2
  3. Fixed Bug announcement of away arming on Door station does not work even if \"Disable Arming sounds on Door Station\" is not checked.
  4. Solved the problem when play reminder on DP is heard on KP after the chime.
  5. Fixed old bug where keypad F key ends menu and # key is pressed before \"Thank You, goodbye\" is completed causes \"No Message\" to be heard on all keypads
Improvements
  1. Wizcomfort can talk to door station when doorbell is not pressed
  2. Improved announcements queuing.
  3. Improved announcements so that they are not heard on door stations unless reminder is programmed for door station and exit arming announcements are permited on the door station.
Bugs
F8 Intercom When receiver press 0 to talk then originator press 0, it cannot talk.
Note that the firmware has been replaced by 5.211. This is to document the features on the firmware for those who may have this version of firmware installed.
The current firmware file can be downloaded from https://www.cytech.biz/firmware.html
Instructions for upgrading Comfort Firmware can be found at http://www.comfortforums.com/forum4/1782.html
Please note that new systems may not come with the latest firmware due to existing stocks in the supply chain. Installers should upgrade to the latest firmware before installation. Existing installed systems do not need the upgraded firmware unless the funcgtionality is to be updated or there are bugs to be fixed which affect the installation.
