Describe Comfort2 start-up process - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Describe Comfort2 start-up process (/thread-2060.html) |
- EziAV - 11-29-2010 Can you please describe the start-up process Comfort goes through after: 1, System power cycle (removal of AC & Battery power) 2, Reset button pushed on the main board 3, Comfigurator Download Is the Start-up Response ran in all of the above situations? Are any other Responses or process ran? I am trying to figure out why a driveway gate opens after a Comfigurator Download. - slychiu - 11-29-2010 Comfigurator full download will cause a Reset Power On also causes a reset The Startup Response runs whenever the system is reset The gate opening may or may not be due to the Startup Response. You may have open zones causing a Zone Response, for example To find out all the events which trigger the Response, do a Right Click on the Response and click \"Show References\" |
