HOW to connect TWS with RIO - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Troubles (https://www.comfortforums.com/forum-77.html) +---- Thread: HOW to connect TWS with RIO (/thread-2051.html) |
- mah_hosary2010 - 11-22-2010 How can i connect TWS PC01-018C with RIO PC01-031C ??? I found that i have to shunt J3 and J4 but this is in newer version PC01-040C not in older version like PC01-018C so this is a problem facing me Waiting for your answer quickly Thank you - ident - 11-22-2010 On which board do you see J3 and J4? - mah_hosary2010 - 11-22-2010 in CSM i thank you so much , i solve it - scyong36 - 01-15-2012 How can i on the alarm (model: comfort intelligent alarm system minor pro)then got come out with the error nulo and the alarm was beep beep sound and cannot turn on... HELP!!! SOS... - ident - 01-16-2012 Hi I cannot understand your problem \"minor pro nul0\" If you are in Malaysia, please call Cytech Tech Support +65 68468701 and qask for Technical Support so you can explan the problem better |
