RIO manual a bit outdated. - Printable Version
+--- Thread: RIO manual a bit outdated. (/thread-1910.html)
- Ingo - 07-05-2010
Guys,
I just received my brand new RIO module and found the current RIO manual to be a bit outdated. It references a couple of shunt/jumpers/switches etc. that doesn\'t exist on the RIO module.
I also see that the picture of the RIO module is also slightly incorrect, it shows a 12V and GND connection and if someone were to connect these to their respective terminals it would probably blow a fuse or something. The actual RIO module has 2 x 12V connections for external devices so please look at your PCB before you connect anything.
Ingo
- slychiu - 07-06-2010
Thanks for the feedback There are several manuals which need updating besides this. We will attempt to keep everything up to date as possible
