Battery Test Location - Printable Version
+--- Thread: Battery Test Location (/thread-1843.html)
- Majik - 05-05-2010
I read the FAQ on the 24 hr battery test and it mentions setting this in a location.
I\'ve checked the worksheet (Comfort Ultra II) for this location, and it doesn\'t mention it.
Can you tell me what the location is for this setting please.
(I would normally set it by comfigurator, but I\'m not able to do that at the moment)
Cheers,
Keith
- hendy - 05-06-2010
The location is 720.
If you use the latest Comfigurator 3 software you can see this location on bottom left corner when the Battery Test Interval (hours) is highlighted.
eg: (720) = 24
The number inside the bracket is the location.
24 is the value stored inside this location, in this case 24 hours.
- Majik - 05-06-2010
Thanks.
Cheers,
Keith
