Add Door station vidéo on PC - Printable Version
+--- Thread: Add Door station vidéo on PC (/thread-1732.html)
- Domoconcept - 01-22-2010
Hello
I wan\'t to know if it\'s possible to integrate audio/ video and door contact on a PC.
I have a software on a touchpanel (with windows 7) witch control my entire KNX installation.
I\'d like to add a door station in this software. I know that the software accept IP camera. Is it possible to integrate the door station like an IP camera, on a PC?
Thanks for your answer
- slychiu - 01-24-2010
Yes. If you add the AUD01 plugin  module on top of one of the UCMs (232, USB or Ethernet) you can connect the voice and mic to the PC and use an application like Wizcomfort (beta software available at http://www.comfortforums.com/view_topic.php?id=1662&forum_id=21 )
This allows the video from an IP camera to be viewed when the door station button is pressed
