Using Internal Telephones - Printable Version
+--- Thread: Using Internal Telephones (/thread-1726.html)
- cgiltrow - 01-18-2010
I have just installed a new Comfort Ultra II at my holiday home.
I do not have a fixed line and have used a GSM module (which works great as an alternative to the fixed line).
I have installed the ringer module (in case I put in a fixed line later) and I do have telephone lines and telephones in the house even though I do not have a telephone connection.
Can I use the internal telephones to interact with Comfort (my wife prefers answering the door station on a telephone) even though I don\'t have an external telephone connection?
Thanks,
Clinton.
- admin - 01-18-2010
In order to use the telephone to answer the door station if you do not have a fixed line connected, you need to uncheck the Ignore Line Cut box in Modules and Settings, otherwise the local phone may not be able to access Comfort
To prevent the Phone Trouble alarm from activating, go to Security Types > Non Detectors alarms > set Phone Trouble to Null (No alarm)
Not 100% sure that this works, please try it
- mindi65 - 01-19-2010
It works. I have this on my site.
