DP02 / DP03x & DM02 - Printable Version
+--- Forum: Door Stations (https://www.comfortforums.com/forum-86.html)
+--- Thread: DP02 / DP03x & DM02 (/thread-1711.html)
- mrtae - 01-02-2010
Can one system install with DP02 & \"DP03x + DM02\" ?? if can, which DP model should i set the 1st ID in the system? Will it causing any problem to RS485 bus?
- slychiu - 01-02-2010
Comfort supports up to 3 Door Stations. They can be DP03 or  DM02. Any Door station can be ID 1 as long as the Number of Door Stations in Comfigurator is set to the total number of Door Stations
