Switch off Standby items - Printable Version
+--- Thread: Switch off Standby items (/thread-1603.html)
- bryanajones - 09-26-2009
Can anyone suggest a way to use comfort to switch on an off items that are in standby?
What I would like is to fit some wall sockets near the TV\'s. Any item such as the TV that goes into standby but would be better off when not in use. I would like to be able to remotely switch the sockets off. I.e. when I leave the house and arm the system, switch off all tv\'s etc.
(hope I explained that ok)
I am about to finish the decorating on the house so if any new cables are needed I need to get these down as soon as possible.
Bryan
- ident - 09-27-2009
ZWave would be ideal for this. The Appliance module plugs into the wall sockets and can be switched by Comfort using the UCM/Zwave
- bryanajones - 09-27-2009
I don\'t want anything bulky or that can be seen. Kind of takes the magic out of it all Sad
I cant afford a total rewire of the house (because I cleaned myself out spending several grand on comfort Smile ) but I\'m about to lay alarm cable and data cables so if there\'s anything I can do at this stage?
