Connecting more than one bellbox ? - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Connecting more than one bellbox ? (/thread-1524.html) |
- muddymickey - 06-21-2009 Is it possible to connect more than one bellbox (each with siren and strobe) to Comfort ? Cheers Lee - ident - 06-22-2009 Yes you can connect more than 1 Siren and strobe(I assume you mean 2 and not 3 or more) Comfort can supply a maximum of 1A to all outputs and devices which include sirens. When 2 sirens are sounding they may take more than 1A, but as long as you have the backup battery connected, this will handle the addtional current required. The siren duration of course must not be unlimited in the Siren Type settings - ident - 06-22-2009 You can also connect extra Sirens to Slaves (SEMs) as they have their own independent power supply and battery |
