Vacation mode interrupted. - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Vacation mode interrupted. (/thread-151.html) |
- gazza - 08-21-2006 I had a real situation where I wondered what might have happened. THe alarm was in vacation mode, and had a program to turn on some lights for 2 hours in the evening. A sensor tripped and set off the alarm (due to high wind) , so I dialed in and switched to security off, then bypassed the sensor, and switched back to vacation mode. I did not know if the vacation program would continue i.e. the lights would have been on, would it continue and then turn them off considering i had changed mode to off then back to vacation? To be safe, I dialed in again, and used the control menu to turn off the lights. But I just wondered if interuppting the vacation mode would have messed up the program for that night at least? - slychiu - 08-22-2006 We have never had this question before, but that is a good one When you disarm and go back into Vacation mode, the Vacation programs will start again, the old ones are ended Say you have a vacation program which turns on the light at 7 PM to 8 PM and off in 2 to 3 hours If you disarm and return to Vacation mode at 7:20 PM and the light had been switched on, the vacation program may try to switch on the light again if the randon time is after7:20 PM, and it would switch it iff as scheduled. If at 7:20 PM the light was not switched on, it would swithc on before 8 PM and switch off as scheduled Hence it would appear like the vacation mode ws not interrupted - gazza - 08-22-2006 Thanks for that. Is the OFFResponse triggered? as if not, I can see that possibly, with a vacation program of 7pm and 5 hours, and a reset at 9pm - if the vacation offreseponse is not triggered at reset, then the lights could remain on all night. Not a problem, as if that is the case, I will just put a check program that runs at midnight (which I guess I should have anyway, incase the x10 signal does not get through) - slychiu - 08-23-2006 No you are correct that the Off response would not be triggered in this case as the vacation program would not have started - gazza - 08-23-2006 Many thanks for the clarification |
