Internal Door - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Internal Door (/thread-1388.html) |
- Warby - 03-04-2009 I have a job that has a door contact on an internal door between the garage and the house. The contact only wants to be active when set to vacation mode. there is also a keypad on one side of the door. If I set the zone type to SwitchNC and use the following response will it work? If SecurityMode = VacationMode Then If Input DC3_Coats <> 0 Then Start EntryDelay End If End If Thanks - ident - 03-05-2009 The Zone Response should be If SecurityMode = VacationMode Then Start EntryDelay End If There is no need to test for InputDC3_coats assuming that this is the door itself You can also make it a Entry Door ZoneType and do this If SecurityMode < VacationMode Then Skip Alarm End If - Warby - 03-05-2009 I like the second example but won\'t it prevent the alarm from setting as there door will be open most of the time? - admin - 03-05-2009 You are right. If it is open most of the time, then that example is not suitable |
